Woodruff keys
Mode
Tool
Workspace: Tool set
Woodruff Key
Architect and Spotlight: Machine Components
Landmark: Add tool to workspace
(see Customizing workspaces)
Multiple key and woodruff key tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a woodruff key:
Click the tool and mode.
Parameter
Description
Standard
Select Imperial or Metric
Nom. Size (in) or (mm)
Select one of the standard key sizes
Key Type
Select the key type
Depth of Keyseat (shaft) / Depth of Keyseat (hub)
Displays the depth of the keyseat shaft and hub, determined by the standard size selected
View
(2D only)
Select the 2D view
Keys
Keyways
